Samsung N150 Plus Fan Replacement
  1. Samsung N150 Plus Fan Replacement, Battery: step 1, image 1 of 1
    • Turn off the computer.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down with the front face down on a flat surface.
  2. Samsung N150 Plus Fan Replacement: step 2, image 1 of 2 Samsung N150 Plus Fan Replacement: step 2, image 2 of 2
    • Slide the left and right switch to the "unlocked" position.
  3. Samsung N150 Plus Fan Replacement: step 3, image 1 of 2 Samsung N150 Plus Fan Replacement: step 3, image 2 of 2
    • While holding the left and right hand switches in the "unlocked" position, push the battery away from the computer.
  4. Samsung N150 Plus Fan Replacement, Back Panel: step 4, image 1 of 1
    • Using the Phillip's 00 screwdriver, unscrew the fourteen 7mm screws until the back panel comes loose.
  5. Samsung N150 Plus Fan Replacement: step 5, image 1 of 1
    • Using either the blue plastic opening tools or spudger tool, wedge one in between the back panel and the laptop.
    • Apply pressure upwards till the back panel pops off.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  6. Samsung N150 Plus Fan Replacement: step 6, image 1 of 2 Samsung N150 Plus Fan Replacement: step 6, image 2 of 2
    • The computer should be open with the motherboard exposed and internal components exposed. You should now be able to access the Fan and RAM. There are more necessary steps to follow before accessing the screen and keyboard.
  7. Samsung N150 Plus Fan Replacement, Fan: step 7, image 1 of 2 Samsung N150 Plus Fan Replacement, Fan: step 7, image 2 of 2
    • Use the phillips #00 screwdriver, to unscrew the two 5mm mounting screws labeled 1 & 2 on the right and left hand side of the metal casing labeled CPU.
  8. Samsung N150 Plus Fan Replacement: step 8, image 1 of 2 Samsung N150 Plus Fan Replacement: step 8, image 2 of 2
    • Unplug the the wires from the white connector attached to the motherboard, by pulling the wires toward you.
    • When pulling on the wires make sure not to detach the wires from the white plug that connects to the motherboard.
  9. Samsung N150 Plus Fan Replacement: step 9, image 1 of 1
    • Remove the metal casing with the fan attached from the motherboard.
  10. Samsung N150 Plus Fan Replacement: step 10, image 1 of 1
    • Use the Phillips #000 screwdriver, to unscrew the three 4mm screws.
  11. Samsung N150 Plus Fan Replacement: step 11, image 1 of 2 Samsung N150 Plus Fan Replacement: step 11, image 2 of 2
    • Remove the fan from the metal CPU housing.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 1,316
