Samsung NP-N102S-B05PH Speaker Replacement
  1. Samsung NP-N102S-B05PH Speaker Replacement, Speaker: step 1, image 1 of 3 Samsung NP-N102S-B05PH Speaker Replacement, Speaker: step 1, image 2 of 3 Samsung NP-N102S-B05PH Speaker Replacement, Speaker: step 1, image 3 of 3
    • Place the laptop face-down on a stable surface.
    • Remove the nine 6.5mm Phillips #0 screws shown.
    • Use the blue opening tool to gently pry the back of the laptop off of the body.
  2. Samsung NP-N102S-B05PH Speaker Replacement: step 2, image 1 of 3 Samsung NP-N102S-B05PH Speaker Replacement: step 2, image 2 of 3 Samsung NP-N102S-B05PH Speaker Replacement: step 2, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the six 4.5mm screws holding the motherboard to the case.
  3. Samsung NP-N102S-B05PH Speaker Replacement: step 3, image 1 of 2 Samsung NP-N102S-B05PH Speaker Replacement: step 3, image 2 of 2
    • Use the spudger to remove the red and black cable located above the speaker from it's connector.
    • Also using the spudger, remove the small ribbon cable located a the bottom of the motherboard, towards the middle.
    • Fold the motherboard back, using the computer hinge as the axis of rotation. The motherboard will still be attached to the case by a few wires.
  4. Samsung NP-N102S-B05PH Speaker Replacement: step 4, image 1 of 1
    • Gently unhook the red and black wires from the plastic clips holding them to the case. This can be done with only your fingers.
  5. Samsung NP-N102S-B05PH Speaker Replacement: step 5, image 1 of 1
    • Using the spudger, lift the speaker up and out of it's holder, as shown. The yellow plastic tape should peel off as well.
Lennon Grimm
247 Reputation
2 Guides authored
USF Tampa, Team 2-4, Nance Fall 2016 Member of USF Tampa, Team 2-4, Nance Fall 2016
USFT-NANCE-F16S2G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 15
All Time: 1,087
