Samsung NP-N210-JA02US Hard Drive Replacement
  1. Samsung NP-N210-JA02US Hard Drive Replacement, Battery: step 1, image 1 of 2 Samsung NP-N210-JA02US Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Carefully slide both locking pins to the unlocked position.
  2. Samsung NP-N210-JA02US Hard Drive Replacement: step 2, image 1 of 1
    • Slide the battery out of its housing.
  3. Samsung NP-N210-JA02US Hard Drive Replacement, Hard Drive Removal: step 3, image 1 of 1
    • Remove the following 14 screws:
    • Thirteen 5 mm Phillips #1 screws
    • One 3.5 mm Philips #001 screw
  4. Samsung NP-N210-JA02US Hard Drive Replacement: step 4, image 1 of 1
    • Carefully insert the plastic opening tool into the seam between the lower casing and the chrome bezel.
  5. Samsung NP-N210-JA02US Hard Drive Replacement: step 5, image 1 of 1
    • Slide the opening tool across all sides of the lower case. Then, lift it up to remove the case and reveal the internal components.
  6. Samsung NP-N210-JA02US Hard Drive Replacement: step 6, image 1 of 3 Samsung NP-N210-JA02US Hard Drive Replacement: step 6, image 2 of 3 Samsung NP-N210-JA02US Hard Drive Replacement: step 6, image 3 of 3
    • Carefully unplug the SATA connector from the hard drive.
  7. Samsung NP-N210-JA02US Hard Drive Replacement: step 7, image 1 of 2 Samsung NP-N210-JA02US Hard Drive Replacement: step 7, image 2 of 2
    • Remove the four black 3.5 mm Philips #1 screws on the (side) of the hard drive.
  8. Samsung NP-N210-JA02US Hard Drive Replacement: step 8, image 1 of 1
    • Gently lift the hard drive from its mounting bracket.
9 other people completed this guide.
Afif Chehabaldeen
401 Reputation
4 Guides authored
USF Tampa, Team 1-3, Nance Fall 2016 Member of USF Tampa, Team 1-3, Nance Fall 2016
USFT-NANCE-F16S1G3
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 31
All Time: 3,619
