Samsung NP-NC10-KA02US Hard Drive Replacement
  1. Samsung NP-NC10-KA02US Hard Drive Replacement, Battery: step 1, image 1 of 2 Samsung NP-NC10-KA02US Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Locate the external battery on the bottom side of the device.
    • Locate the tab on the right side of the battery.
    • Shift the tab to the left.
  2. Samsung NP-NC10-KA02US Hard Drive Replacement: step 2, image 1 of 1
    • Locate the tab on the left side of the device's battery.
    • Push the left tab to the right.
  3. Samsung NP-NC10-KA02US Hard Drive Replacement: step 3, image 1 of 1
    • Pull the battery up from the device.
  4. Samsung NP-NC10-KA02US Hard Drive Replacement, Back Plate: step 4, image 1 of 1
    • Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
  5. Samsung NP-NC10-KA02US Hard Drive Replacement: step 5, image 1 of 1
    • Remove all 14 of the 3.93 mm screws using a PH1 screw bit.
  6. Samsung NP-NC10-KA02US Hard Drive Replacement: step 6, image 1 of 2 Samsung NP-NC10-KA02US Hard Drive Replacement: step 6, image 2 of 2
    • Using two plastic opening tools remove the back plate.
    • These plastic opening tools have a flat-head that extends as a wedge which are utilized to separate pressure fit plastic components without causing any damage to them.
    • The back plate is now removed exposing all of the hardware components.
  7. Samsung NP-NC10-KA02US Hard Drive Replacement, Hard Drive: step 7, image 1 of 2 Samsung NP-NC10-KA02US Hard Drive Replacement, Hard Drive: step 7, image 2 of 2
    • Locate the hard drive.
    • Remove the one 3.93 mm screw holding the hard drive in place using a PH1 screw bit.
  8. Samsung NP-NC10-KA02US Hard Drive Replacement: step 8, image 1 of 2 Samsung NP-NC10-KA02US Hard Drive Replacement: step 8, image 2 of 2
    • Hold the end of the hard drive farthest from where it is connected to the netbook. Then gently pull in the opposite direction of where the hard drive is connected.
    • Your hard drive is now removed.
5 other people completed this guide.
Brian Smith
405 Reputation
2 Guides authored
USF Tampa, Team 1-1, Sullivan Fall 2016 Member of USF Tampa, Team 1-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G1
3 Members
6 Guides authored
2 Comments
Thanks for your kindness.
นพไกร ใจดี - Reply
Where can I get the screws from
Lucky Jacob - Reply
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 45
All Time: 6,100
