Samsung NP-R540-JA09US Front Panel Replacement
  1. Samsung NP-R540-JA09US Front Panel Replacement, Battery: step 1, image 1 of 1
    • Turn off laptop before starting.
    • Remove power cable before starting.
    • Flip the laptop over so that the bottom of the laptop is facing upwards.
  2. Samsung NP-R540-JA09US Front Panel Replacement: step 2, image 1 of 1
    • Pull the two latches outward.
  3. Samsung NP-R540-JA09US Front Panel Replacement: step 3, image 1 of 2 Samsung NP-R540-JA09US Front Panel Replacement: step 3, image 2 of 2
    • Slide the battery out of the laptop.
  4. Samsung NP-R540-JA09US Front Panel Replacement, Optical Drive: step 4, image 1 of 1
    • Remove securing screw with the PH0 head.
  5. Samsung NP-R540-JA09US Front Panel Replacement: step 5, image 1 of 1
    • Slide the optical drive out and remove it from the device.
  6. Samsung NP-R540-JA09US Front Panel Replacement, Keyboard: step 6, image 1 of 1
    • Remove the two Phillips #0 screws labeled KBD.
    • There are 5 clips along the top of the keyboard. Insert a thin opener tool (iSessamo tool or similar) between each clip and the keyboard tray to release it.
    • Make sure to pry the metal keyboard base and not the keycaps.
  7. Samsung NP-R540-JA09US Front Panel Replacement: step 8, image 1 of 1
    • Do not bend your keyboard as shown in this picture.
    • Lift the keyboard up to release catches on the sides, then slide the keyboard towards the screen to slide tabs out of the slots at the bottom.
  8. Samsung NP-R540-JA09US Front Panel Replacement: step 9, image 1 of 2 Samsung NP-R540-JA09US Front Panel Replacement: step 9, image 2 of 2
    • Disconnect the keyboard cable from the motherboard.
  9. Samsung NP-R540-JA09US Front Panel Replacement, Front Panel: step 10, image 1 of 1
    • Remove the two screws with a Phillips #00 screwdriver.
  10. Samsung NP-R540-JA09US Front Panel Replacement: step 11, image 1 of 1
    • Remove the highlighted screws with a Phillips #0 Screwdriver.
  11. Samsung NP-R540-JA09US Front Panel Replacement: step 12, image 1 of 3 Samsung NP-R540-JA09US Front Panel Replacement: step 12, image 2 of 3 Samsung NP-R540-JA09US Front Panel Replacement: step 12, image 3 of 3
    • Pry the front panel away from the base with an Opening Tool.
  12. Samsung NP-R540-JA09US Front Panel Replacement: step 13, image 1 of 2 Samsung NP-R540-JA09US Front Panel Replacement: step 13, image 2 of 2
    • Disconnect the speaker wire from the motherboard.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 703
