Samsung NP305E5A-A03US Battery Replacement
  1. Samsung NP305E5A-A03US Battery Replacement, Battery: step 1, image 1 of 1
    • Be sure to power down your laptop before replacing your battery.
    • Turn your laptop upside down so that the battery component is facing you.
  2. Samsung NP305E5A-A03US Battery Replacement: step 2, image 1 of 1
    • Place your thumbs on the lock tabs.
    • Slide the tabs with your thumbs in an outward direction (in the direction of the arrows).
    • You should hear a click when you properly slide the tabs all the way.
  3. Samsung NP305E5A-A03US Battery Replacement: step 3, image 1 of 2 Samsung NP305E5A-A03US Battery Replacement: step 3, image 2 of 2
    • Pull the battery out of the laptop towards yourself to safely remove the battery.
    • If you are discarding the battery, please do not throw it away in the trash. Instead find a local battery recycling facility that will not damage the environment.
3 other people completed this guide.
Kris Stobbe
585 Reputation
3 Guides authored
Baylor, Team 5-7, Williams Fall 2016 Member of Baylor, Team 5-7, Williams Fall 2016
BU-WILLIAMS-F16S5G7
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 20
All Time: 543
