Samsung NP305E5A-A03US RAM Replacement
  1. Samsung NP305E5A-A03US RAM Replacement, Hard Drive: step 1, image 1 of 1
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  2. Samsung NP305E5A-A03US RAM Replacement: step 2, image 1 of 1
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  3. Samsung NP305E5A-A03US RAM Replacement: step 3, image 1 of 2 Samsung NP305E5A-A03US RAM Replacement: step 3, image 2 of 2
    • Pull the panel towards you to remove the panel.
  4. Samsung NP305E5A-A03US RAM Replacement: step 4, image 1 of 1
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US RAM Replacement: step 5, image 1 of 2 Samsung NP305E5A-A03US RAM Replacement: step 5, image 2 of 2
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  6. Samsung NP305E5A-A03US RAM Replacement: step 6, image 1 of 1
    • Remove the Hard Drive by lifting it towards you.
  7. Samsung NP305E5A-A03US RAM Replacement, RAM: step 7, image 1 of 1
    • Place your thumbs on the metal tabs.
    • Push outwards on the metal tabs to release the RAM.
  8. Samsung NP305E5A-A03US RAM Replacement: step 8, image 1 of 2 Samsung NP305E5A-A03US RAM Replacement: step 8, image 2 of 2
    • Pull out the RAM towards you to remove it from the laptop.
2 other people completed this guide.
Julia Dotter
224 Reputation
1 Guide authored
Baylor, Team 5-7, Williams Fall 2016 Member of Baylor, Team 5-7, Williams Fall 2016
BU-WILLIAMS-F16S5G7
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 430
