Samsung NP36535C-S05US CD Drive Replacement
  1. Samsung NP36535C-S05US CD Drive Replacement, Battery: step 1, image 1 of 1
    • Turn the computer off.
    • Disconnect the charging cable from the laptop.
    • Failure to disconnect cable may result in electric shock.
    • Flip the laptop face down on a flat surface.
  2. Samsung NP36535C-S05US CD Drive Replacement: step 2, image 1 of 1
    • Slide the left and right switches to the unlock position.
  3. Samsung NP36535C-S05US CD Drive Replacement: step 3, image 1 of 2 Samsung NP36535C-S05US CD Drive Replacement: step 3, image 2 of 2
    • While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
  4. Samsung NP36535C-S05US CD Drive Replacement, ODD/HDD/Memory panel: step 4, image 1 of 3 Samsung NP36535C-S05US CD Drive Replacement, ODD/HDD/Memory panel: step 4, image 2 of 3 Samsung NP36535C-S05US CD Drive Replacement, ODD/HDD/Memory panel: step 4, image 3 of 3
    • Locate the ODD/HDD/Memory panel.
    • Remove the 1.9 mm screw located on the ODD/HDD/Memory panel with the Philips #0 screwdriver.
    • Slide the ODD/HDD/Memory panel away from the device to remove it.
  5. Samsung NP36535C-S05US CD Drive Replacement, CD Drive: step 5, image 1 of 2 Samsung NP36535C-S05US CD Drive Replacement, CD Drive: step 5, image 2 of 2
    • Locate the screw on the right side of the SDD port.
    • Remove the 2.25 mm screw located on the right side of the SDD port with the Philips #0 screwdriver.
  6. Samsung NP36535C-S05US CD Drive Replacement: step 6, image 1 of 3 Samsung NP36535C-S05US CD Drive Replacement: step 6, image 2 of 3 Samsung NP36535C-S05US CD Drive Replacement: step 6, image 3 of 3
    • Locate the CD drive and slide the drive out of the computer.
One Comment
Hie guys my laptop is not displaying
please help what should i do
semzeajunior - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 344
