Samsung NP540U3C-A02UB Battery Replacement
  1. Samsung NP540U3C-A02UB Battery Replacement, Hard Drive: step 1, image 1 of 1
    • Turn off the laptop before beginning disassembly and unplug it from the power cord.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Battery Replacement: step 2, image 1 of 2 Samsung NP540U3C-A02UB Battery Replacement: step 2, image 2 of 2
    • Remove one 4 mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Battery Replacement: step 3, image 1 of 3 Samsung NP540U3C-A02UB Battery Replacement: step 3, image 2 of 3 Samsung NP540U3C-A02UB Battery Replacement: step 3, image 3 of 3
    • Gently release the 3 clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Battery Replacement: step 4, image 1 of 2 Samsung NP540U3C-A02UB Battery Replacement: step 4, image 2 of 2
    • Remove the four 6 mm Phillips #00 screws attaching the hard drive to the case.
  5. Samsung NP540U3C-A02UB Battery Replacement: step 5, image 1 of 2 Samsung NP540U3C-A02UB Battery Replacement: step 5, image 2 of 2
    • Using the plastic opening tool, push the hard drive connector clip upwards in order to release the cable.
  6. Samsung NP540U3C-A02UB Battery Replacement: step 6, image 1 of 2 Samsung NP540U3C-A02UB Battery Replacement: step 6, image 2 of 2
    • Remove the hard drive from the case.
  7. Samsung NP540U3C-A02UB Battery Replacement, Battery: step 7, image 1 of 2 Samsung NP540U3C-A02UB Battery Replacement, Battery: step 7, image 2 of 2
    • Remove the following screws holding the case together:
    • 6x 4mm Phillips #00 screws.
    • 3x 6mm Phillips #00 screws.
  8. Samsung NP540U3C-A02UB Battery Replacement: step 8, image 1 of 2 Samsung NP540U3C-A02UB Battery Replacement: step 8, image 2 of 2
    • Using the opening tool, remove the two rubber pads just above the hard drive cover.
  9. Samsung NP540U3C-A02UB Battery Replacement: step 9, image 1 of 2 Samsung NP540U3C-A02UB Battery Replacement: step 9, image 2 of 2
    • Remove the 2x 4mm Phillips #00 screws formerly concealed by the pads.
  10. Samsung NP540U3C-A02UB Battery Replacement: step 10, image 1 of 1
    • Using the plastic opening tool, gently lift and remove the back cover.
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
  11. Samsung NP540U3C-A02UB Battery Replacement: step 11, image 1 of 2 Samsung NP540U3C-A02UB Battery Replacement: step 11, image 2 of 2
    • Using your hands or the plastic opening tool, gently remove the tape holding the wires in place.
  12. Samsung NP540U3C-A02UB Battery Replacement: step 12, image 1 of 3 Samsung NP540U3C-A02UB Battery Replacement: step 12, image 2 of 3 Samsung NP540U3C-A02UB Battery Replacement: step 12, image 3 of 3
    • Remove the 4x 4mm Phillips #00 screws securing the battery to the chassis.
  13. Samsung NP540U3C-A02UB Battery Replacement: step 13, image 1 of 2 Samsung NP540U3C-A02UB Battery Replacement: step 13, image 2 of 2
    • Using the plastic opening tool, gently pull the battery connector towards the battery to disconnect it.
  14. Samsung NP540U3C-A02UB Battery Replacement: step 14, image 1 of 1
    • Remove the battery from the laptop.
Alejandro
253 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 24
All Time: 877
