Samsung NX Mini Flash Assembly Replacement
  1. Samsung NX Mini Flash Assembly Replacement, Battery: step 1, image 1 of 3 Samsung NX Mini Flash Assembly Replacement, Battery: step 1, image 2 of 3 Samsung NX Mini Flash Assembly Replacement, Battery: step 1, image 3 of 3
    • Orient the camera so the button panel and LCD are facing you.
    • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
  2. Samsung NX Mini Flash Assembly Replacement: step 2, image 1 of 2 Samsung NX Mini Flash Assembly Replacement: step 2, image 2 of 2
    • Push the blue trapdoor to the left to release the battery, and remove the battery.
    • There is no battery shown in this photo.
  3. Samsung NX Mini Flash Assembly Replacement, Front Case: step 3, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
  4. Samsung NX Mini Flash Assembly Replacement: step 4, image 1 of 1
    • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
  5. Samsung NX Mini Flash Assembly Replacement: step 5, image 1 of 1
    • Remove the four 5 mm Phillips #00 screws from the lens assembly.
  6. Samsung NX Mini Flash Assembly Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the metal lens mount by hand or with tweezers.
    • Be careful not to touch the sensor in the center of the lens assembly.
  7. Samsung NX Mini Flash Assembly Replacement: step 7, image 1 of 1
    • Use tweezers to remove the inner metal ring.
  8. Samsung NX Mini Flash Assembly Replacement: step 8, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
  9. Samsung NX Mini Flash Assembly Replacement: step 9, image 1 of 2 Samsung NX Mini Flash Assembly Replacement: step 9, image 2 of 2
    • Use your hands to slowly pull the front casing away from the camera.
    • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
  10. Samsung NX Mini Flash Assembly Replacement, Sensor: step 10, image 1 of 3 Samsung NX Mini Flash Assembly Replacement, Sensor: step 10, image 2 of 3 Samsung NX Mini Flash Assembly Replacement, Sensor: step 10, image 3 of 3
    Buy
    • Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
    • Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
    • Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
    • The gold lens contacts lying beneath the ribbon cable become loose when the screw and contact cover are removed.
  11. Samsung NX Mini Flash Assembly Replacement: step 11, image 1 of 2 Samsung NX Mini Flash Assembly Replacement: step 11, image 2 of 2
    • Remove the four 4 mm Phillips #00 screws holding the sensor mount in place.
  12. Samsung NX Mini Flash Assembly Replacement: step 12, image 1 of 3 Samsung NX Mini Flash Assembly Replacement: step 12, image 2 of 3 Samsung NX Mini Flash Assembly Replacement: step 12, image 3 of 3
    • Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board.
    • Remove the battery compartment.
  13. Samsung NX Mini Flash Assembly Replacement: step 13, image 1 of 2 Samsung NX Mini Flash Assembly Replacement: step 13, image 2 of 2
    • Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
  14. Samsung NX Mini Flash Assembly Replacement: step 14, image 1 of 1
    • Gently remove the sensor mount from the camera case.
  15. Samsung NX Mini Flash Assembly Replacement, Motherboard: step 15, image 1 of 2 Samsung NX Mini Flash Assembly Replacement, Motherboard: step 15, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the 3 mm screw located below the wifi antenna.
  16. Samsung NX Mini Flash Assembly Replacement: step 16, image 1 of 2 Samsung NX Mini Flash Assembly Replacement: step 16, image 2 of 2
    Buy
    • Use tweezers to disconnect the wifi antenna from the motherboard.
  17. Samsung NX Mini Flash Assembly Replacement: step 17, image 1 of 3 Samsung NX Mini Flash Assembly Replacement: step 17, image 2 of 3 Samsung NX Mini Flash Assembly Replacement: step 17, image 3 of 3
    • Use a spudger to disconnect the LCD ribbon cable by prying it straight up from the motherboard.
  18. Samsung NX Mini Flash Assembly Replacement: step 18, image 1 of 3 Samsung NX Mini Flash Assembly Replacement: step 18, image 2 of 3 Samsung NX Mini Flash Assembly Replacement: step 18, image 3 of 3
    • Use a spudger to unlock the topmost ZIF connector by flipping open the black flap.
  19. Samsung NX Mini Flash Assembly Replacement: step 19, image 1 of 2 Samsung NX Mini Flash Assembly Replacement: step 19, image 2 of 2
    • Insert the pointed end of a spudger into the hole in the middle of the ribbon cable.
    • Gently pull the spudger back to slide the ribbon cable out of its connector.
  20. Samsung NX Mini Flash Assembly Replacement: step 20, image 1 of 3 Samsung NX Mini Flash Assembly Replacement: step 20, image 2 of 3 Samsung NX Mini Flash Assembly Replacement: step 20, image 3 of 3
    • Disconnect the blue ribbon cable from the motherboard.
    • Insert the pointed end of a spudger into the hole in the top of the ribbon.
    • Gently pull the ribbon from the connector.
  21. Samsung NX Mini Flash Assembly Replacement: step 21, image 1 of 1
    • Remove the motherboard from the camera.
  22. Samsung NX Mini Flash Assembly Replacement, Flash Assembly: step 22, image 1 of 3 Samsung NX Mini Flash Assembly Replacement, Flash Assembly: step 22, image 2 of 3 Samsung NX Mini Flash Assembly Replacement, Flash Assembly: step 22, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws holding the flash assembly to the camera case.
  23. Samsung NX Mini Flash Assembly Replacement: step 23, image 1 of 2 Samsung NX Mini Flash Assembly Replacement: step 23, image 2 of 2
    • Remove the flash assembly by gently pulling it away from the case.
    • You may need to use a spudger to release some of the clips holding the assembly in place.
    • Avoid touching the ends of the capacitor (the large black cylinder on the right). Capacitors that haven't been discharged may cause electric shock. Learn how to discharge a capacitor here.
Kelsea Weber
21,077 Reputation
32 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 19
All Time: 795
