Samsung NX Mini Front Case Replacement
  1. Samsung NX Mini Front Case Replacement, Battery: step 1, image 1 of 3 Samsung NX Mini Front Case Replacement, Battery: step 1, image 2 of 3 Samsung NX Mini Front Case Replacement, Battery: step 1, image 3 of 3
    • Orient the camera so the button panel and LCD are facing you.
    • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
  2. Samsung NX Mini Front Case Replacement: step 2, image 1 of 2 Samsung NX Mini Front Case Replacement: step 2, image 2 of 2
    • Push the blue trapdoor to the left to release the battery, and remove the battery.
    • There is no battery shown in this photo.
  3. Samsung NX Mini Front Case Replacement, Front Case: step 3, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
  4. Samsung NX Mini Front Case Replacement: step 4, image 1 of 1
    • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
  5. Samsung NX Mini Front Case Replacement: step 5, image 1 of 1
    • Remove the four 5 mm Phillips #00 screws from the lens assembly.
  6. Samsung NX Mini Front Case Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the metal lens mount by hand or with tweezers.
    • Be careful not to touch the sensor in the center of the lens assembly.
  7. Samsung NX Mini Front Case Replacement: step 7, image 1 of 1
    • Use tweezers to remove the inner metal ring.
  8. Samsung NX Mini Front Case Replacement: step 8, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
  9. Samsung NX Mini Front Case Replacement: step 9, image 1 of 2 Samsung NX Mini Front Case Replacement: step 9, image 2 of 2
    • Use your hands to slowly pull the front casing away from the camera.
    • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
Kelsea Weber
21,077 Reputation
32 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 20
All Time: 734
