Samsung NX1000 Back Panel Components Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Samsung NX1000 Back Panel Components Replacement, Back Panel Components: step 1, image 1 of 2 Samsung NX1000 Back Panel Components Replacement, Back Panel Components: step 1, image 2 of 2
    • Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver.
  2. Samsung NX1000 Back Panel Components Replacement: step 2, image 1 of 3 Samsung NX1000 Back Panel Components Replacement: step 2, image 2 of 3 Samsung NX1000 Back Panel Components Replacement: step 2, image 3 of 3
    • Lift up the grey tab on the ZIF connector with the spudger to remove the ribbon.
    • Using both thumbs push the ribbon out of the ZIF connection.
  3. Samsung NX1000 Back Panel Components Replacement: step 3, image 1 of 1
    • Use the metal spudger to pick the bottom of the plastic piece while simultaneously using your index finger to push down on the larger metal slab. This will cause the metal plate with the large ribbon to slide down and out of the plastic back panel.
    • Do not disconnect the blue ribbon.
Yesenia
717 Reputation
6 Guides authored
Cal Poly, Team 20-13, Maness Winter 2015 Member of Cal Poly, Team 20-13, Maness Winter 2015
CPSU-MANESS-W15S20G13
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 156
