Samsung NX2000 Lens Assembly Replacement
  1. Samsung NX2000 Lens Assembly Replacement, Lens Assembly: step 1, image 1 of 2 Samsung NX2000 Lens Assembly Replacement, Lens Assembly: step 1, image 2 of 2
    • Begin by pressing the lens lock button to the right of the lens.
    • Release the button and turn the lens in a clockwise motion until you have removed the lens.
  2. Samsung NX2000 Lens Assembly Replacement: step 2, image 1 of 3 Samsung NX2000 Lens Assembly Replacement: step 2, image 2 of 3 Samsung NX2000 Lens Assembly Replacement: step 2, image 3 of 3
    • Make sure your camera is turned off and flip your device upside down.
    • Slide the battery switch to the left and open the battery compartment.
    • Push the blue button up inside the battery compartment and remove the battery.
  3. Samsung NX2000 Lens Assembly Replacement: step 3, image 1 of 3 Samsung NX2000 Lens Assembly Replacement: step 3, image 2 of 3 Samsung NX2000 Lens Assembly Replacement: step 3, image 3 of 3
    • Remove the four 4mm screws highlighted here with the Y0 screwdriver.
    • Using a tweezer, gently remove the outer silver lens lining.
    • Underneath will lie a black ring, which needs to removed using the same tweezer.
  4. Samsung NX2000 Lens Assembly Replacement: step 4, image 1 of 3 Samsung NX2000 Lens Assembly Replacement: step 4, image 2 of 3 Samsung NX2000 Lens Assembly Replacement: step 4, image 3 of 3
    • Remove the final silver ring from the lens assembly using a tweezer.
    • Using a slanted tweezer, remove the highlighted pyramid screw from the compartment shown.
    • Remove the spring from the same compartment using the same tool.
Katarina Raic
288 Reputation
2 Guides authored
USF Tampa, Team 7-4, Cheng Spring 2016 Member of USF Tampa, Team 7-4, Cheng Spring 2016
USFT-CHENG-S16S7G4
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 905
