Samsung NX3000 Lens Assembly Replacement
  1. Samsung NX3000 Lens Assembly Replacement, Battery: step 1, image 1 of 3 Samsung NX3000 Lens Assembly Replacement, Battery: step 1, image 2 of 3 Samsung NX3000 Lens Assembly Replacement, Battery: step 1, image 3 of 3
    • Turn the camera upside down. Only remove the lens if you have to in order to access the battery compartment, as dust particles could easily enter the main body and fall onto the delicate sensor.
    • Slide the button to the left to open the battery compartment.
    • Push the blue button up to release the battery.
    • The battery is not shown in these photos.
  2. Samsung NX3000 Lens Assembly Replacement, Lens Assembly: step 2, image 1 of 2 Samsung NX3000 Lens Assembly Replacement, Lens Assembly: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the four 7.3 mm Phillips screws from the front of the lens assembly.
    • Remove the silver ring with tweezers.
  3. Samsung NX3000 Lens Assembly Replacement: step 3, image 1 of 2 Samsung NX3000 Lens Assembly Replacement: step 3, image 2 of 2
    • Use tweezers to remove the black plastic ring and small metal ring inside the lens assembly.
  4. Samsung NX3000 Lens Assembly Replacement: step 4, image 1 of 3 Samsung NX3000 Lens Assembly Replacement: step 4, image 2 of 3 Samsung NX3000 Lens Assembly Replacement: step 4, image 3 of 3
    • Use tweezers to lift the pyramid screw and spring from the lens assembly.
Kelsea Weber
21,132 Reputation
32 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 1,782
