Samsung NX500 Screen Side Encasement Replacement
  1. Samsung NX500 Screen Side Encasement Replacement, Battery: step 1, image 1 of 2 Samsung NX500 Screen Side Encasement Replacement, Battery: step 1, image 2 of 2
    • Pull the switch on the bottom of the camera back with your thumb.
  2. Samsung NX500 Screen Side Encasement Replacement: step 2, image 1 of 2 Samsung NX500 Screen Side Encasement Replacement: step 2, image 2 of 2
    • Push second switch(blue) forward with your thumb.
  3. Samsung NX500 Screen Side Encasement Replacement: step 3, image 1 of 1
    • Pull out battery.
  4. Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: step 4, image 1 of 3 Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: step 4, image 2 of 3 Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: step 4, image 3 of 3
    • Open the screen exposing the hinge cover and place the plastic opening tool inside.
    • Pry the hinge cover up by moving the plastic opening tool in a downward motion.
    • Remove the black 4mm Phillips #000 screw that is revealed once the hinge cover is removed.
  5. Samsung NX500 Screen Side Encasement Replacement: step 5, image 1 of 3 Samsung NX500 Screen Side Encasement Replacement: step 5, image 2 of 3 Samsung NX500 Screen Side Encasement Replacement: step 5, image 3 of 3
    • Unscrew the two 4 mm Phillips #000 screws on the right hand side of the camera using the screwdriver.
    • Unscrew five more 4 mm Phillips #000 screws that are located at the bottom of the camera with the screwdriver.
    • In the second step, do not the remove the two 4 mm Phillips #000 screen on the screen.
    • Remove the last exterior 4 mm Phillips #000 screws on the left hand side of the camera with the scredriver.
  6. Samsung NX500 Screen Side Encasement Replacement: step 6, image 1 of 2 Samsung NX500 Screen Side Encasement Replacement: step 6, image 2 of 2
    • Use the plastic opening tool in a downward motion around each side of the camera to pry the casing open.
    • The casing should be removed easily; you shouldn't have to use much force.
  7. Samsung NX500 Screen Side Encasement Replacement: step 7, image 1 of 2 Samsung NX500 Screen Side Encasement Replacement: step 7, image 2 of 2
    • Locate the black ribbon at the bottom left of the camera's interior.
    • Place the plastic opening tool under the black ribbon connector.
    • Remove the cable by moving your plastic opening tool in a downward motion.
    • There is zero to little force needed to remove this ribbon.
carter grenewicz
204 Reputation
2 Guides authored
USF Tampa, Team 18-5, Blackwell Fall 2016 Member of USF Tampa, Team 18-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G5
3 Members
12 Guides authored
One Comment
your dumb. idot
Nick Furio - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 964
