Samsung PL20 Lens Replacement
  1. Samsung PL20 Lens Replacement, Lens: step 1, image 1 of 3 Samsung PL20 Lens Replacement, Lens: step 1, image 2 of 3 Samsung PL20 Lens Replacement, Lens: step 1, image 3 of 3
    • Remove the battery and the memory card from the device.
    • Remove the two screws on the side of the device, to the left of the camera lens.
  2. Samsung PL20 Lens Replacement: step 2, image 1 of 3 Samsung PL20 Lens Replacement: step 2, image 2 of 3 Samsung PL20 Lens Replacement: step 2, image 3 of 3
    • Remove the single screw from the bottom of the device.
    • Remove the two screws on the side of the the device, to the right of the camera lens.
    • Using a plastic opening tool, pry the outside casing apart. Start from the battery compartment and work around the seem of the casing.
  3. Samsung PL20 Lens Replacement: step 3, image 1 of 3 Samsung PL20 Lens Replacement: step 3, image 2 of 3 Samsung PL20 Lens Replacement: step 3, image 3 of 3
    • Remove the back panel, revealing the LCD screen.
    • Pull the LCD screen out of its holder. Once you have access to the connecting strip, flip the clip upwards releasing the screen completely and remove.
  4. Samsung PL20 Lens Replacement: step 4, image 1 of 3 Samsung PL20 Lens Replacement: step 4, image 2 of 3 Samsung PL20 Lens Replacement: step 4, image 3 of 3
    • Gently pull the front panel from the device.
    • Remove the two screws attaching the LCD screen holder to the device.
    • Remove the screen holder from the rest of the device.
  5. Samsung PL20 Lens Replacement: step 5, image 1 of 3 Samsung PL20 Lens Replacement: step 5, image 2 of 3 Samsung PL20 Lens Replacement: step 5, image 3 of 3
    • Flip the grey clip upwards, releasing the connector from the device.
    • Disconnect the ribbon cable extending from the left side.
    • Disconnect the ribbon cable extending from the button bar.
    • Remove the 2 screws.
  6. Samsung PL20 Lens Replacement: step 6, image 1 of 3 Samsung PL20 Lens Replacement: step 6, image 2 of 3 Samsung PL20 Lens Replacement: step 6, image 3 of 3
    • Remove these 3 screws. releasing the lens from the logic board.
    • Remove the lens from the logic board.
oldturkey03
837,368 Reputation
123 Guides authored
2 Guide Comments
Beware there is a capacitor that stores a charge even when the battery is removed. On my camera i touched it, it created a short circuit, i got a shock, and it killed my camera.
morrisettema - Reply
如果螺丝不慎遗失应该买多大的
742339702@qq.com - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 3,541
