Samsung Q330 Keyboard Replacement
  1. Samsung Q330 Keyboard Replacement, Opening the back panel.: step 1, image 1 of 2 Samsung Q330 Keyboard Replacement, Opening the back panel.: step 1, image 2 of 2
    • Unscrew all the screws holding the back panel in place.
    • Remove the battery and the small panel to reveal more screws.
    • Remove the HDD and RAM.
    • Slide out the DVD drive.
  2. Samsung Q330 Keyboard Replacement, The insides.: step 2, image 1 of 2 Samsung Q330 Keyboard Replacement, The insides.: step 2, image 2 of 2
    • Unscrew the heatsink and fan assembly. Disconnect the fan and remove it.
    • Remove the screws that hold the motherboard in place
    • Disconnect the touchpad, keyboard, USB module and Wi-Fi module.
    • Disconnect the power, screen and speaker connectors.
    • Unscrew the hinges and remove the display.
    • Remove the motherboard.
  3. Samsung Q330 Keyboard Replacement, Replacing the keyboard.: step 3, image 1 of 3 Samsung Q330 Keyboard Replacement, Replacing the keyboard.: step 3, image 2 of 3 Samsung Q330 Keyboard Replacement, Replacing the keyboard.: step 3, image 3 of 3
    • Peel and remove the black cover.
    • Use a soldering iron with a big tip, to melt the plastic rivets that hold the metal case for the keyboard.
    • Use a prying tool the remove the metal case.
    • Remove the old keyboard, place the new one and dont forget to place the metal case on top of it.
    • You can reuse the black cover is you want.
Simeon Brankov
6,502 Reputation
51 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 150
