Samsung RC512 RAM Replacement
  1. Samsung RC512 RAM Replacement, Battery: step 1, image 1 of 1
    • Place the laptop upside down.
  2. Samsung RC512 RAM Replacement: step 2, image 1 of 2 Samsung RC512 RAM Replacement: step 2, image 2 of 2
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
  3. Samsung RC512 RAM Replacement, Back Panel: step 3, image 1 of 3 Samsung RC512 RAM Replacement, Back Panel: step 3, image 2 of 3 Samsung RC512 RAM Replacement, Back Panel: step 3, image 3 of 3
    • Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
    • Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
    • Carefully remove the back panel..
  4. Samsung RC512 RAM Replacement, RAM: step 4, image 1 of 1
    • Slide the hinges outwards to release the RAM.
    • RAM will pop up by itself. If not, lift the RAM up to about 45 degrees.
  5. Samsung RC512 RAM Replacement: step 5, image 1 of 2 Samsung RC512 RAM Replacement: step 5, image 2 of 2
    • Carefully slide the RAM away from the slot to remove it.
    • Repeat step 4 to remove another RAM.
jando
917 Reputation
8 Guides authored
USF Tampa, Team 18-2, Blackwell Fall 2016 Member of USF Tampa, Team 18-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G2
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 487
