Samsung RC512 Screen Replacement
  1. Samsung RC512 Screen Replacement, Battery: step 1, image 1 of 1
    • Place the laptop upside down.
  2. Samsung RC512 Screen Replacement: step 2, image 1 of 2 Samsung RC512 Screen Replacement: step 2, image 2 of 2
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
  3. Samsung RC512 Screen Replacement, Screen: step 3, image 1 of 3 Samsung RC512 Screen Replacement, Screen: step 3, image 2 of 3 Samsung RC512 Screen Replacement, Screen: step 3, image 3 of 3
    • The Laptop should be off before removing the battery.
  4. Samsung RC512 Screen Replacement: step 4, image 1 of 3 Samsung RC512 Screen Replacement: step 4, image 2 of 3 Samsung RC512 Screen Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the gray covers with tweezers to expose the 4mm screws.
    • Using a Phillips #0 screwdriver, remove the four 4 mm Phillips #0 screws.
  5. Samsung RC512 Screen Replacement: step 5, image 1 of 2 Samsung RC512 Screen Replacement: step 5, image 2 of 2
    • Insert the blue plastic opening tool into the bezel and rear housing of the screen.
    • Use the plastic opening tool to pop open the claps that hold the casing on the screen.
    • Work your way around the sides carefully and continue this to the bottom.
    • You may use your fingers to help remove the cover.
  6. Samsung RC512 Screen Replacement: step 6, image 1 of 2 Samsung RC512 Screen Replacement: step 6, image 2 of 2
    • With the Phillips #0 screwdriver remove the six 3 mm screws, which mount the screen onto the base of the laptop.
    • As you remove the last two screws, support the screen. As the screws are taken out, the screen will begin to fall forward.
  7. Samsung RC512 Screen Replacement: step 7, image 1 of 3 Samsung RC512 Screen Replacement: step 7, image 2 of 3 Samsung RC512 Screen Replacement: step 7, image 3 of 3
    • Gently lay the LCD onto the keyboard.
    • Do not separate the LCD screen and the back panel from each other. The video connector still connects the two together.
    • Remove the tape that secures the video connector to the LCD screen with tweezers.
    • Grasp the video connector at its base and pull it away from the LCD screen.
    • The only thing holding the screen will be the clear tape causing it to come out easily.
jando
917 Reputation
8 Guides authored
USF Tampa, Team 18-2, Blackwell Fall 2016 Member of USF Tampa, Team 18-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G2
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 753
