Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement
  1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unplug your refrigerator: step 1, image 1 of 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: step 2, image 1 of 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: step 2, image 2 of 2
    • Open both French doors for the refrigerator compartment.
  3. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: step 3, image 1 of 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: step 3, image 2 of 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: step 3, image 3 of 3
    • Pull the ice tray straight out of its housing and remove it.
  4. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: step 4, image 1 of 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: step 4, image 2 of 2
    • Use a Phillips screwdriver to remove the 16.5 mm‑long screw securing the cable cover panel.
  5. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: step 5, image 1 of 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: step 5, image 2 of 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: step 5, image 3 of 3
    • Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
    • Remove the cable cover panel.
    • During reassembly, make sure this panel clips fully in place, or the ice tray won't slide in properly.
  6. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: step 6, image 1 of 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: step 6, image 2 of 2
    • Disconnect the left-most yellow connector:
    • Squeeze the locking tab with the red mark with your fingers
    • Rock the connector gently side to side to disconnect it
    • Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
  7. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the air tunnel: step 7, image 1 of 1
    • Use a Phillips screwdriver to remove the 16.5 mm-long screw securing the air tunnel flap.
  8. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: step 8, image 1 of 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: step 8, image 2 of 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: step 8, image 3 of 3
    • A plastic clip holds the air tunnel flap in place.
    • Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
  9. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: step 9, image 1 of 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: step 9, image 2 of 2
    • Use your fingers to pull the air tunnel flap down enough to access the internals.
  10. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: step 10, image 1 of 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: step 10, image 2 of 2
    • Use a flathead screwdriver to gently pry the refrigerant loop down by 1–1.5 cm.
    • During reassembly, use your fingers to push the refrigerant loop back up.
  11. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: step 11, image 1 of 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: step 11, image 2 of 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: step 11, image 3 of 3
    • A plastic clip holds the icemaker in place.
    • Use your fingers to press and release the plastic clip.
    • This clip is stiff and may require substantial force.
  12. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: step 12, image 1 of 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: step 12, image 2 of 2
    • Pull the front edge of the icemaker assembly down slightly to loosen it.
    • Be careful not to bend the refrigerant loop too much as you pull the front edge, or you'll damage the loop.
    • Carefully slide the icemaker assembly out of its housing.
  13. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: step 13, image 1 of 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: step 13, image 2 of 2
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
35 Members
603 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 102
All Time: 823
