Samsung RF28R7351 Fuse Block Module Replacement
Video Overview
  1. Samsung RF28R7351 Fuse Block Module Replacement, Fuse Box Module: step 1, image 1 of 1
    • Begin by disconnecting the power to the appliance
    • It is also recommended to test the outlet for the proper voltage
    • Also, turn off the water.
  2. Samsung RF28R7351 Fuse Block Module Replacement: step 2, image 1 of 1
    • You will need a Phillips screwdriver to remove the cover, which is held on by five Phillips screws.
    • Remove the five Phillips screws.
    • The lower middle screw is a machine screw thread, so keep it separate for reinstallation.
  3. Samsung RF28R7351 Fuse Block Module Replacement: step 4, image 1 of 2 Samsung RF28R7351 Fuse Block Module Replacement: step 4, image 2 of 2
    • With the panel removed, you now have clear access to the fuse block.
  4. Samsung RF28R7351 Fuse Block Module Replacement, Test continuity of fuses: step 5, image 1 of 2 Samsung RF28R7351 Fuse Block Module Replacement, Test continuity of fuses: step 5, image 2 of 2
    • The main reason why you'd be accessing your fuse block is if the unit has no power
    • Once the fuse block is removed, you can use your multimeter to test continuity on the metal sides of each one of these fuses.
    • (How to use a multimeter)
    • If one is blown, the fuse block will need to be replaced.
  5. Samsung RF28R7351 Fuse Block Module Replacement, Disconnecting the fuse block: step 6, image 1 of 2 Samsung RF28R7351 Fuse Block Module Replacement, Disconnecting the fuse block: step 6, image 2 of 2
  6. Samsung RF28R7351 Fuse Block Module Replacement, Installing a new fuse block: step 7, image 1 of 2 Samsung RF28R7351 Fuse Block Module Replacement, Installing a new fuse block: step 7, image 2 of 2
    • When installing your new fuse block, first install the wiring.
    • Make sure the connector is securely locked into place.
    • The red wire goes with the red, and the blue with the blue.
    • Swing it in at an angle and pop it in place.
  7. Samsung RF28R7351 Fuse Block Module Replacement, Reinstall the panel cover: step 8, image 1 of 1
    • Once the new fuse block is installed, you can reinstall the panel cover.
    • To reinstall your panel cover, first bring in the top at an angle and drop it on those hooks.
  8. Samsung RF28R7351 Fuse Block Module Replacement: step 9, image 1 of 3 Samsung RF28R7351 Fuse Block Module Replacement: step 9, image 2 of 3 Samsung RF28R7351 Fuse Block Module Replacement: step 9, image 3 of 3
Finish Line
eCuration
450,167 Reputation
252 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 22
All Time: 544
