Samsung Water Filter (Horizontal Filter) Replacement
  1. Samsung Water Filter (Horizontal Filter) Replacement, Open the refrigerator doors: step 1, image 1 of 2 Samsung Water Filter (Horizontal Filter) Replacement, Open the refrigerator doors: step 1, image 2 of 2
    • Open both French doors for the refrigerator compartment.
  2. Samsung Water Filter (Horizontal Filter) Replacement, Locate the water filter: step 2, image 1 of 2 Samsung Water Filter (Horizontal Filter) Replacement, Locate the water filter: step 2, image 2 of 2
    • Locate the water filter.
    • On this model, the filter can be found at the bottom of the main compartment, between the crisper drawers.
  3. Samsung Water Filter (Horizontal Filter) Replacement, Remove the filter: step 3, image 1 of 2 Samsung Water Filter (Horizontal Filter) Replacement, Remove the filter: step 3, image 2 of 2
    • Twist the water filter cap counter-clockwise until it's loosened from its housing.
  4. Samsung Water Filter (Horizontal Filter) Replacement: step 4, image 1 of 2 Samsung Water Filter (Horizontal Filter) Replacement: step 4, image 2 of 2
    • Pull the water filter straight out of its housing and remove it.
    • When you install the replacement filter, remember to remove the cap on the new filter.
  5. Samsung Water Filter (Horizontal Filter) Replacement: step 5, image 1 of 2 Samsung Water Filter (Horizontal Filter) Replacement: step 5, image 2 of 2
    • Run the water to flush the filter and check for leaks for a few minutes.
    • Press reset on the filter indicator.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
34 Members
597 Guides authored
2 Comments
IS there a difference from the HAF-QIN and the HAF-QIN/EXP
bigjon7379 - Reply
Does anyone have instructions on taking out the filter assembly to find where leaks are coming from?
Larry - Reply
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 96
All Time: 15,565
