Samsung Rant Battery Replacement
  1. Samsung Rant Battery Replacement, Back Cover: step 1, image 1 of 1
    • Turn the phone over in the palm of your hand, with the screen facing down.
    • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
    • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
    • You should now be able to lift the plate completely off of the phone.
  2. Samsung Rant Battery Replacement, Battery: step 2, image 1 of 1
    • Carefully remove the battery from the phone.
*New Battery information: Standard Lithium Ion (Li-Ion); Talk time: 5.6 hours max. (336 minutes)
Todd
1 Reputation
1 Guide authored
James Madison, Team 1-6, Allen Fall 2011 Member of James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
4 Members
12 Guides authored
1 Guide Comment
*New batteries need to be charged before use.
*You should charge your battery in an area that is free of moisture, extreme cold or extreme heat.
*Refer to the repair manual (Samsung Rant Device page above) for information on purchasing a battery and battery life.
Denise Cooper - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 1,603
