Samsung Rant Keypad Replacement
  1. Samsung Rant Keypad Replacement, Back Cover: step 1, image 1 of 1
    • Turn the phone over in the palm of your hand, with the screen facing down.
    • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
    • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
    • You should now be able to lift the plate completely off of the phone.
  2. Samsung Rant Keypad Replacement, Battery: step 2, image 1 of 1
    • Carefully remove the battery from the phone.
  3. Samsung Rant Keypad Replacement, Rear Case: step 3, image 1 of 1
    • Use a Phillips #00 screwdriver to loosen and remove all 3 screws.
  4. Samsung Rant Keypad Replacement: step 4, image 1 of 1
    • Gently separate the rear case from the front case.
  5. Samsung Rant Keypad Replacement, Keypad: step 5, image 1 of 2 Samsung Rant Keypad Replacement, Keypad: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Using a pair of tweezers, grip the keypad gently.
    • Lift the keypad out of the phone and replace it (if necessary).
Denise Cooper
31 Reputation
3 Guides authored
James Madison, Team 1-6, Allen Fall 2011 Member of James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 1,626
