Samsung Refrigerator Control Panel Wiring Fix
  1. Samsung Refrigerator Control Panel Wiring Fix, Description of the problem: step 1, image 1 of 2 Samsung Refrigerator Control Panel Wiring Fix, Description of the problem: step 1, image 2 of 2
    • This guide applies when the control panel of your Samsung fridge is starting to act up.
    • In my case it was unresponsive to some buttons and the display showed incomplete digits
    • This might be relevant for a number of models.
  2. Samsung Refrigerator Control Panel Wiring Fix, Control panel: step 2, image 1 of 1
    • In you want, you can pop out the control panel by putting a knife behind it.
    • This is not necessary but helps to identify the connections. In my case, pressing the top button connected connector pin 1 to ground (pin7) via a 10k resistor.
  3. Samsung Refrigerator Control Panel Wiring Fix, Wiring issue: step 3, image 1 of 1
    • The problem in my case was the wiring loom that runs through the top hinge of the fridge door.
    • As you can see it is broken in multiple places. Its design is a bit poor as the plastic in the hinge is too sharp.
    • You can fix it by soldering and covering the connections in shrink tubing.
Mark
492 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 77
All Time: 4,137
