Samsung Refrigerator Door Sensors Replacement
  1. Samsung Refrigerator Door Sensors Replacement, Unplug your refrigerator: step 1, image 1 of 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Door Sensors Replacement, Remove the hinge cover: step 2, image 1 of 1
    • Remove the screws securing the hinge cover (aka top table) on the top of the refrigerator.
  3. Samsung Refrigerator Door Sensors Replacement: step 3, image 1 of 1
    • Lift the edges of the hinge cover to loosen it from the refrigerator.
    • Don't try to fully remove the cover, as it's still attached to the refrigerator by a few cables.
    • Flip the hinge cover over to access the cables underneath.
  4. Samsung Refrigerator Door Sensors Replacement: step 4, image 1 of 2 Samsung Refrigerator Door Sensors Replacement: step 4, image 2 of 2
    • Use your fingers to release the wire connectors under the hinge cover.
    • Disconnect the wiring so you can remove the hinge cover.
  5. Samsung Refrigerator Door Sensors Replacement: step 5, image 1 of 1
    • Remove the hinge cover.
  6. Samsung Refrigerator Door Sensors Replacement, Sensor information: step 6, image 1 of 2 Samsung Refrigerator Door Sensors Replacement, Sensor information: step 6, image 2 of 2
    • The door sensors are located in the hinge cover. In this example, the hinge cover has two door sensors:
    • The left door sensor
    • The left door sensor connector
    • The right door sensor
    • The right door sensor connector
    • Depending on your situation, you may need to replace either or both sensors.
  7. Samsung Refrigerator Door Sensors Replacement, Remove the sensor: step 7, image 1 of 2 Samsung Refrigerator Door Sensors Replacement, Remove the sensor: step 7, image 2 of 2
    • Use your fingers to squeeze and disconnect the sensor cable connector.
  8. Samsung Refrigerator Door Sensors Replacement: step 8, image 1 of 2 Samsung Refrigerator Door Sensors Replacement: step 8, image 2 of 2
    • Use a spudger or a flathead screwdriver to pry the sensor out of its retaining clips.
  9. Samsung Refrigerator Door Sensors Replacement: step 9, image 1 of 1
    • Remove the door sensor.
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
35 Members
603 Guides authored
0 Comments
Past 24 Hours: 18
Past 7 Days: 62
Past 30 Days: 309
All Time: 3,463
