Samsung Refrigerator Evaporator Drain Clip Replacement
  1. Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: step 1, image 1 of 3 Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: step 1, image 2 of 3 Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: step 1, image 3 of 3
    • Using a spudger, pry off the cap covering the topmost screw.
  2. Samsung Refrigerator Evaporator Drain Clip Replacement: step 2, image 1 of 3 Samsung Refrigerator Evaporator Drain Clip Replacement: step 2, image 2 of 3 Samsung Refrigerator Evaporator Drain Clip Replacement: step 2, image 3 of 3
    • Remove three 12.7 mm screws using a Phillips #0 screwdriver.
  3. Samsung Refrigerator Evaporator Drain Clip Replacement: step 3, image 1 of 3 Samsung Refrigerator Evaporator Drain Clip Replacement: step 3, image 2 of 3 Samsung Refrigerator Evaporator Drain Clip Replacement: step 3, image 3 of 3
    • Use your hands or a spudger to pry back the plastic cover starting from the bottom.
    • Once all the clips are pulled out, loosen the cover by pushing it slightly up and out.
    • Do not pull the cover off yet; there are still connectors attaching the cover to the fridge.
  4. Samsung Refrigerator Evaporator Drain Clip Replacement: step 4, image 1 of 3 Samsung Refrigerator Evaporator Drain Clip Replacement: step 4, image 2 of 3 Samsung Refrigerator Evaporator Drain Clip Replacement: step 4, image 3 of 3
    • Gently unplug both connectors.
    • Remember their orientations as it will be important during reassembly.
  5. Samsung Refrigerator Evaporator Drain Clip Replacement: step 5, image 1 of 1
    • Using a hair dryer or heat gun, melt down any ice buildup in the draining well.
  6. Samsung Refrigerator Evaporator Drain Clip Replacement: step 6, image 1 of 1
    • Cut out the old evaporating clip using a pair of cutting pliers.
  7. Samsung Refrigerator Evaporator Drain Clip Replacement: step 7, image 1 of 3 Samsung Refrigerator Evaporator Drain Clip Replacement: step 7, image 2 of 3 Samsung Refrigerator Evaporator Drain Clip Replacement: step 7, image 3 of 3
    • Replace the old clip with a new evaporating clip.
7 other people completed this guide.
Deep Patel
299 Reputation
1 Guide authored
3 Comments
Problem only resolved for about 6 months post clip replacement. Now every 2 months back to defrosting my refrigerator, under the crisper drawer. Now the entire section of the drain is frozen. Very frustraing.
David Kahan - Reply
Here's another video of this replacement. Head over to the refrigerator leaking water wiki for more fixes for freezing lines.
nicO - Reply
Past 24 Hours: 7
Past 7 Days: 65
Past 30 Days: 357
All Time: 16,261
