Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement
  1. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Unplug your refrigerator: step 1, image 1 of 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Open the refrigerator doors: step 2, image 1 of 2 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Open the refrigerator doors: step 2, image 2 of 2
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the shelves: step 3, image 1 of 2 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the shelves: step 3, image 2 of 2
    • Remove all the loose shelves and bins from the refrigerator compartment.
    • The bottom shelf is clipped in place. Follow the next step to remove it.
  4. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 4, image 1 of 3 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 4, image 2 of 3 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 4, image 3 of 3
    • Two stiff plastic tabs (one on each side) secure the bottom shelf in place.
    • Press both plastic tabs firmly with your fingers and lift upward to unclip the bottom shelf.
    • If the shelf doesn't unclip, you can try using a flathead screwdriver to press each clip in.
    • Remove the bottom shelf.
  5. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: step 5, image 1 of 3 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: step 5, image 2 of 3 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: step 5, image 3 of 3
    • Use a flathead screwdriver to pry and remove the top screw cover on the evaporator cover.
  6. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 6, image 1 of 1
    • Remove the screws securing the evaporator cover.
  7. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 7, image 1 of 3 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 7, image 2 of 3 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 7, image 3 of 3
    • Grasp the right edge of the evaporator cover with your hands and swing it outwards toward you.
    • Don't try to fully remove the cover in this step, as it's connected by several wires.
  8. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 8, image 1 of 1
    • Squeeze and disconnect all the wire connectors connecting the evaporator cover to the refrigerator.
  9. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 9, image 1 of 2 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 9, image 2 of 2
    • Pull the evaporator cover towards you and remove it.
  10. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the evaporator fan: step 10, image 1 of 1
    • Remove the screws securing the fan bracket to the evaporator cover.
  11. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 11, image 1 of 2 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 11, image 2 of 2
    • Remove the fan cable from the cover clips.
    • If you have trouble getting the cable out of the clips, squeeze the clips with pliers to create a wider gap.
  12. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 12, image 1 of 2 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 12, image 2 of 2
    • Lift the loose edge of the fan bracket up.
  13. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 13, image 1 of 2 Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 13, image 2 of 2
    • The fan is pressure-fit in place with some foam insulation.
    • Use your fingers to press the fan out of its recess.
  14. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: step 14, image 1 of 1
    • Remove the fan.
    • During reassembly, be sure to install the fan in the right orientation: the side with the center label should face down, towards the evaporator cover.
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
15,927 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
35 Members
603 Guides authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 39
Past 30 Days: 223
All Time: 1,523
