Samsung Rogue Motherboard Replacement
  1. Samsung Rogue Motherboard Replacement, Battery: step 1, image 1 of 2 Samsung Rogue Motherboard Replacement, Battery: step 1, image 2 of 2
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
  2. Samsung Rogue Motherboard Replacement: step 2, image 1 of 2 Samsung Rogue Motherboard Replacement: step 2, image 2 of 2
    • You can now remove the battery by prying it up with your finger.
  3. Samsung Rogue Motherboard Replacement, Motherboard: step 3, image 1 of 1
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
  4. Samsung Rogue Motherboard Replacement: step 4, image 1 of 1
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
  5. Samsung Rogue Motherboard Replacement: step 5, image 1 of 3 Samsung Rogue Motherboard Replacement: step 5, image 2 of 3 Samsung Rogue Motherboard Replacement: step 5, image 3 of 3
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
  6. Samsung Rogue Motherboard Replacement: step 6, image 1 of 1
    • Remove the two 3.45 mm Philips screws below the white sticker.
  7. Samsung Rogue Motherboard Replacement: step 7, image 1 of 2 Samsung Rogue Motherboard Replacement: step 7, image 2 of 2
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
  8. Samsung Rogue Motherboard Replacement: step 8, image 1 of 2 Samsung Rogue Motherboard Replacement: step 8, image 2 of 2
    • Use a plastic opening tool to disconnect the film from the motherboard.
  9. Samsung Rogue Motherboard Replacement, Speaker/Antenna: step 9, image 1 of 1
    • On the underside of the motherboard, remove the single 3.3mm Philips screw.
  10. Samsung Rogue Motherboard Replacement: step 10, image 1 of 3 Samsung Rogue Motherboard Replacement: step 10, image 2 of 3 Samsung Rogue Motherboard Replacement: step 10, image 3 of 3
    • The speaker and the antenna are both connected on the same black piece.
    • Use a plastic opening tool to pop off the edges of the speaker/antenna piece from the motherboard.
    • Turn over the motherboard and carefully lift the speaker/antenna piece straight up.
    • The camera is held in the middle of the speaker/antenna piece. Make sure to lift directly up when lifting the speaker/antenna piece, otherwise you can risk damaging the camera.
  11. Samsung Rogue Motherboard Replacement, Camera: step 11, image 1 of 3 Samsung Rogue Motherboard Replacement, Camera: step 11, image 2 of 3 Samsung Rogue Motherboard Replacement, Camera: step 11, image 3 of 3
    • With two fingers carefully detach the camera from the motherboard by lifting straight up.
    • Do not pick it up by the camera itself. Handle the little black box it is attached to instead.
  12. Samsung Rogue Motherboard Replacement, Motherboard: step 12, image 1 of 2 Samsung Rogue Motherboard Replacement, Motherboard: step 12, image 2 of 2
    • Use a plastic opening tool to take the silver plate off of the motherboard.
Blaine Nesbit
7 Reputation
1 Guide authored
Cal Poly, Team 7-32, Maness Spring 2012 Member of Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 Members
20 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 44
All Time: 923
