Samsung S760 LCD Screen Replacement Guide
  1. Samsung S760 LCD Screen Replacement Guide, Battery: step 1, image 1 of 3 Samsung S760 LCD Screen Replacement Guide, Battery: step 1, image 2 of 3 Samsung S760 LCD Screen Replacement Guide, Battery: step 1, image 3 of 3
    • Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
  2. Samsung S760 LCD Screen Replacement Guide: step 2, image 1 of 2 Samsung S760 LCD Screen Replacement Guide: step 2, image 2 of 2
    • Tip the camera as to gently slide the batteries out of the camera.
  3. Samsung S760 LCD Screen Replacement Guide, LCD Screen: step 3, image 1 of 3 Samsung S760 LCD Screen Replacement Guide, LCD Screen: step 3, image 2 of 3 Samsung S760 LCD Screen Replacement Guide, LCD Screen: step 3, image 3 of 3
    • Locate and remove the six 4mm screws on the sides of the camera, using the Phillip Screwdriver #000 bit.
    • Screw dimensions refer to screw lengths.
  4. Samsung S760 LCD Screen Replacement Guide: step 4, image 1 of 2 Samsung S760 LCD Screen Replacement Guide: step 4, image 2 of 2
    • Use the plastic opening tool to open pry open the back case, following alongside the edge of the case if need be.
  5. Samsung S760 LCD Screen Replacement Guide: step 5, image 1 of 3 Samsung S760 LCD Screen Replacement Guide: step 5, image 2 of 3 Samsung S760 LCD Screen Replacement Guide: step 5, image 3 of 3
    • Under the LCD screen, remove the metal plate by removing the two 3mm screws holding it in place.
  6. Samsung S760 LCD Screen Replacement Guide: step 6, image 1 of 2 Samsung S760 LCD Screen Replacement Guide: step 6, image 2 of 2
    • Use the plastic opening tool to gently lift the small gray clip covering the ribbon cable connection.
    • Carefully pull out the ribbon cable.
3 other people completed this guide.
Isaiah Weidmann
357 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 17
All Time: 1,193
