Samsung S860 LCD Screen Replacement
  1. Samsung S860 LCD Screen Replacement, LCD Screen: step 1, image 1 of 2 Samsung S860 LCD Screen Replacement, LCD Screen: step 1, image 2 of 2
    • Remove all screws along the edges of the camera, using a #00 Phillips screwdriver.
  2. Samsung S860 LCD Screen Replacement: step 2, image 1 of 1
    • Slide open the battery compartment cover before removing the exterior covers of the camera.
  3. Samsung S860 LCD Screen Replacement: step 3, image 1 of 3 Samsung S860 LCD Screen Replacement: step 3, image 2 of 3 Samsung S860 LCD Screen Replacement: step 3, image 3 of 3
    • Carefully pull the back case (the side showing the LCD screen) away from the front half.
    • There are clips securing the top of the back case. Do not be afraid to use the proper amount of force to remove the back case.
    • Turn the camera around to the front (the lens side). Carefully remove the front case.
    • There are also clips on the lens' side as well, so do not be afraid to use force.
  4. Samsung S860 LCD Screen Replacement: step 4, image 1 of 2 Samsung S860 LCD Screen Replacement: step 4, image 2 of 2
    • Position the camera so the LCD screen is facing you.
    • Remove the LCD screen from the screen plate.
    • Replace the broken LCD screen with the functioning LCD screen.
3 other people completed this guide.
Kando Ogunrinola
203 Reputation
3 Guides authored
Cal Poly, Team 33-72, Johann Spring 2010 Member of Cal Poly, Team 33-72, Johann Spring 2010
CPSU-JOHANN-S10S33G72
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 51
All Time: 9,433
