Samsung SCH-A670 Screen Casing Replacement
  1. Samsung SCH-A670 Screen Casing Replacement, Battery Cover: step 1, image 1 of 1
    • Slide the latch on the back of the phone up.
  2. Samsung SCH-A670 Screen Casing Replacement, Battery: step 2, image 1 of 1
    • Remove the battery.
  3. Samsung SCH-A670 Screen Casing Replacement, Logic Board: step 3, image 1 of 1
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  4. Samsung SCH-A670 Screen Casing Replacement: step 4, image 1 of 1
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
  5. Samsung SCH-A670 Screen Casing Replacement: step 5, image 1 of 1
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
  6. Samsung SCH-A670 Screen Casing Replacement: step 6, image 1 of 2 Samsung SCH-A670 Screen Casing Replacement: step 6, image 2 of 2
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
  7. Samsung SCH-A670 Screen Casing Replacement: step 7, image 1 of 1
    • Gently pry up the ribbon-type connector with the spudger.
  8. Samsung SCH-A670 Screen Casing Replacement: step 8, image 1 of 1
    • Carefully pry the logic board from the case with the spudger.
  9. Samsung SCH-A670 Screen Casing Replacement, Keypad: step 9, image 1 of 1
    • Once the logic board has been removed, peel the keypad up.
  10. Samsung SCH-A670 Screen Casing Replacement, Keypad Housing: step 10, image 1 of 2 Samsung SCH-A670 Screen Casing Replacement, Keypad Housing: step 10, image 2 of 2
    • When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
  11. Samsung SCH-A670 Screen Casing Replacement, Screen Casing: step 11, image 1 of 1
    • Remove screws with #0 Phillips screwdriver.
  12. Samsung SCH-A670 Screen Casing Replacement: step 12, image 1 of 1
    • Carefully pry apart the casing with the spudger tool.
Nathan Brink
19 Reputation
7 Guides authored
Cal Poly, Team 34-59, Forte Spring 2010 Member of Cal Poly, Team 34-59, Forte Spring 2010
CPSU-FORTE-S10S34G59
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,939
