Samsung SGH-A737 Screen Replacement
    • Remove battery from the back of the device.
    • Use a Phillips head screw driver to unscrew six screws on back on the device.
    • Using the same screw driver, slide up the screen and remove two more screws beside the camera.
    • Remove side buttons and pop out circuit board, this will expose two more screws. Remove these and keep them separate from the rest.
    • Remove the Samsung sticker to expose two metal tabs.
  1. Samsung SGH-A737 Screen  Replacement: step 6, image 1 of 1
    • Peel off the black strip to expose two screws. Remove these.
  2. Samsung SGH-A737 Screen  Replacement: step 7, image 1 of 1
    • Use a Phillips head screwdriver to remove the four screws on the back of the screen.
  3. Samsung SGH-A737 Screen  Replacement: step 8, image 1 of 1
    • Once you have exposed the circuit board, peel off the green tape at the bottom. This will allow the removal of the screen.
    • Before removing the screen, disconnect the orange tape at the top of the circuit board. You can do this by opening up the small lock.
    • With the lock opened, the circuit board will automatically detach when you pull it out in step 11.
    • Use a flathead screwdriver to reach under the circuit board and pry it up. You should hear a tearing sound; this is the glue separating from the screen.
    • Once you have pried it up, the screen should come out easily. The camera and its microphone are attached at the top(outlined in red).
    • With the screen removed, you can then put the new one in. You must attach the orange strip to the new circuit board to properly install it.
Tommy
101 Reputation
2 Guides authored
Ohio State, Team 1-3, Garvin Spring 2016 Member of Ohio State, Team 1-3, Garvin Spring 2016
OSU-GARVIN-S16S1G3
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 263
