Samsung SPEX SCH-R210 Speaker Replacement
  1. Samsung SPEX SCH-R210 Speaker Replacement, Back Cover: step 1, image 1 of 3 Samsung SPEX SCH-R210 Speaker Replacement, Back Cover: step 1, image 2 of 3 Samsung SPEX SCH-R210 Speaker Replacement, Back Cover: step 1, image 3 of 3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
  2. Samsung SPEX SCH-R210 Speaker Replacement, Battery: step 2, image 1 of 1
    • Locate the access notch at the end of the battery compartment.
  3. Samsung SPEX SCH-R210 Speaker Replacement: step 3, image 1 of 1
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
  4. Samsung SPEX SCH-R210 Speaker Replacement, Speaker: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to unscrew the four 3/16" screws holding the black plastic cover of the phone in place.
  5. Samsung SPEX SCH-R210 Speaker Replacement: step 5, image 1 of 2 Samsung SPEX SCH-R210 Speaker Replacement: step 5, image 2 of 2
    • Remove the small, black headphone cover from the left side of the phone by gently pulling it off.
    • Remove the small, black volume cover from the right side of the phone by gentle pulling it off.
  6. Samsung SPEX SCH-R210 Speaker Replacement: step 6, image 1 of 1
    • Remove the black plastic cover from the back of the phone by slowly pulling it off. This may take a little effort.
  7. Samsung SPEX SCH-R210 Speaker Replacement: step 7, image 1 of 1
    • Once the plastic cover is removed, turn the cover over so that the insides are visible.
    • Using your fingernail, pry out the small, grey, circular speaker from the cover.
  8. Samsung SPEX SCH-R210 Speaker Replacement: step 8, image 1 of 1
    • Remove the old speaker, discard it and replace it with a new speaker.
2 other people completed this guide.
Susan
331 Reputation
3 Guides authored
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Member of WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 457
