Samsung ST150F LCD Screen Replacement
  1. Samsung ST150F LCD Screen Replacement, Outer Casing: step 1, image 1 of 3 Samsung ST150F LCD Screen Replacement, Outer Casing: step 1, image 2 of 3 Samsung ST150F LCD Screen Replacement, Outer Casing: step 1, image 3 of 3
    • Remove these screws from the camera using a phillips head screwdriver.
  2. Samsung ST150F LCD Screen Replacement: step 2, image 1 of 1
    • Lay the camera down on the table and remove the metal shell from the front.
  3. Samsung ST150F LCD Screen Replacement: step 3, image 1 of 1
    • Wedge a spudger/flathead screwdriver inside of the shell where the screws were to pry the shell off of the back.
  4. Samsung ST150F LCD Screen Replacement: step 4, image 1 of 1
    • Remove the shell the from the back of the camera.
  5. Samsung ST150F LCD Screen Replacement, LCD Screen: step 5, image 1 of 1
    • Remove the Phillips head screw from the rear panel control board to reveal the LCD's connection to the motherboard.
  6. Samsung ST150F LCD Screen Replacement: step 6, image 1 of 1
    • Use a spudger to flip up the light gray lever(as shown in the photo). This will release the screen so that you may pull it out.
  7. Samsung ST150F LCD Screen Replacement: step 7, image 1 of 1
    • Pull the screen out of the mother board.
5 other people completed this guide.
Nicholas Pavao
496 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 1,181
