Samsung ST76 Motherboard Replacement
  1. Samsung ST76 Motherboard Replacement, Back Panel: step 1, image 1 of 3 Samsung ST76 Motherboard Replacement, Back Panel: step 1, image 2 of 3 Samsung ST76 Motherboard Replacement, Back Panel: step 1, image 3 of 3
    • Use a Phillips head screwdriver to remove 5 screws from the camera. There are 2 4mm screws on the left side, 2 2mm screws on the right side and 1 4mm screw on the bottom.
    • Do not mix the 5 screws; they are different sizes.
  2. Samsung ST76 Motherboard Replacement: step 2, image 1 of 2 Samsung ST76 Motherboard Replacement: step 2, image 2 of 2
    • Use your fingers to pull the back cover off.
  3. Samsung ST76 Motherboard Replacement, Screen: step 3, image 1 of 2 Samsung ST76 Motherboard Replacement, Screen: step 3, image 2 of 2
    • Separate the button panel to reveal the port holding the screen on.
    • Use a plastic opening tool to help with this task.
  4. Samsung ST76 Motherboard Replacement: step 4, image 1 of 2 Samsung ST76 Motherboard Replacement: step 4, image 2 of 2
    • Remove the yellow cable by pulling gently upwards, away from the inside of the camera, until it separates from its port.
  5. Samsung ST76 Motherboard Replacement, Motherboard: step 5, image 1 of 3 Samsung ST76 Motherboard Replacement, Motherboard: step 5, image 2 of 3 Samsung ST76 Motherboard Replacement, Motherboard: step 5, image 3 of 3
    • Remove 2 3mm screws from the metal plate covering the motherboard and lens using a Phillips #00 screw driver.
  6. Samsung ST76 Motherboard Replacement: step 6, image 1 of 3 Samsung ST76 Motherboard Replacement: step 6, image 2 of 3 Samsung ST76 Motherboard Replacement: step 6, image 3 of 3
    • Remove the 4 cables connecting the motherboard to the camera body.
2 other people completed this guide.
Jessica Bain
408 Reputation
2 Guides authored
Marist, Team 1-6, Laflen Spring 2015 Member of Marist, Team 1-6, Laflen Spring 2015
MARS-LAFLEN-S15S1G6
2 Members
8 Guides authored
3 Guide Comments
Thanks for great info. I should add that one can also clean the sensor. Sensor is circular plate with 3 screws at back of the lens. Now the camera is like new!
compand - Reply
Where can you buy a replacement motherboard?
Demaree Wiitala - Reply
ST76 and ST77 are very close relatives.
As it can be seen on the parts, some are marked: ”ST77”
Paul
Paul Cohen - Reply
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 31
All Time: 1,430
