Samsung ST76 Screen Replacement
  1. Samsung ST76 Screen Replacement, Back Panel: step 1, image 1 of 3 Samsung ST76 Screen Replacement, Back Panel: step 1, image 2 of 3 Samsung ST76 Screen Replacement, Back Panel: step 1, image 3 of 3
    • Use a Phillips head screwdriver to remove 5 screws from the camera. There are 2 4mm screws on the left side, 2 2mm screws on the right side and 1 4mm screw on the bottom.
    • Do not mix the 5 screws; they are different sizes.
  2. Samsung ST76 Screen Replacement: step 2, image 1 of 2 Samsung ST76 Screen Replacement: step 2, image 2 of 2
    • Use your fingers to pull the back cover off.
  3. Samsung ST76 Screen Replacement, Screen: step 3, image 1 of 2 Samsung ST76 Screen Replacement, Screen: step 3, image 2 of 2
    • Separate the button panel to reveal the port holding the screen on.
    • Use a plastic opening tool to help with this task.
  4. Samsung ST76 Screen Replacement: step 4, image 1 of 2 Samsung ST76 Screen Replacement: step 4, image 2 of 2
    • Remove the yellow cable by pulling gently upwards, away from the inside of the camera, until it separates from its port.
3 other people completed this guide.
Angela Fierst
376 Reputation
2 Guides authored
Marist, Team 1-6, Laflen Spring 2015 Member of Marist, Team 1-6, Laflen Spring 2015
MARS-LAFLEN-S15S1G6
2 Members
8 Guides authored
1 Guide Comment
Where did you buy a replacement screen?
Demaree Wiitala - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 861
