Samsung Series 5 3G Chromebook Battery Replacement
  1. Samsung Series 5 3G Chromebook Battery Replacement, Back Cover: step 1, image 1 of 2 Samsung Series 5 3G Chromebook Battery Replacement, Back Cover: step 1, image 2 of 2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Remove the rubber feet from the bottom of the panel using your fingernails.
    • Remove all the seven screws from the bottom panel.
  2. Samsung Series 5 3G Chromebook Battery Replacement: step 2, image 1 of 2 Samsung Series 5 3G Chromebook Battery Replacement: step 2, image 2 of 2
    • Loosen the back cover panel using a spudger.
  3. Samsung Series 5 3G Chromebook Battery Replacement: step 3, image 1 of 2 Samsung Series 5 3G Chromebook Battery Replacement: step 3, image 2 of 2
    • Once you work your way around, you can remove the panel.
  4. Samsung Series 5 3G Chromebook Battery Replacement, Battery: step 4, image 1 of 3 Samsung Series 5 3G Chromebook Battery Replacement, Battery: step 4, image 2 of 3 Samsung Series 5 3G Chromebook Battery Replacement, Battery: step 4, image 3 of 3
    • Remove three Phillips screws from the battery.
    • Disconnect the battery from the motherboard.
    • Lift the battery up and away from the laptop to remove it.
11 other people completed this guide.
One Comment
i want the chromebook battery
Christopher Jorgensen - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 19,226
