Samsung Series 5 3G Chromebook CPU Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Samsung Series 5 3G Chromebook CPU Replacement, Back Cover: step 1, image 1 of 2 Samsung Series 5 3G Chromebook CPU Replacement, Back Cover: step 1, image 2 of 2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Remove the rubber feet from the bottom of the panel using your fingernails.
    • Remove all the seven screws from the bottom panel.
  2. Samsung Series 5 3G Chromebook CPU Replacement: step 2, image 1 of 2 Samsung Series 5 3G Chromebook CPU Replacement: step 2, image 2 of 2
    • Loosen the back cover panel using a spudger.
  3. Samsung Series 5 3G Chromebook CPU Replacement: step 3, image 1 of 2 Samsung Series 5 3G Chromebook CPU Replacement: step 3, image 2 of 2
    • Once you work your way around, you can remove the panel.
  4. Samsung Series 5 3G Chromebook CPU Replacement, CPU: step 4, image 1 of 3 Samsung Series 5 3G Chromebook CPU Replacement, CPU: step 4, image 2 of 3 Samsung Series 5 3G Chromebook CPU Replacement, CPU: step 4, image 3 of 3
    • Remove the two Phillips screws on the fan.
  5. Samsung Series 5 3G Chromebook CPU Replacement: step 5, image 1 of 3 Samsung Series 5 3G Chromebook CPU Replacement: step 5, image 2 of 3 Samsung Series 5 3G Chromebook CPU Replacement: step 5, image 3 of 3
    • Unplug the wires from the motherboard
    • You can now see the CPU attached to the motherboard.
    • The CPU cannot be removed from the motherboard.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,360
