Samsung Series 5 Ultrabook RAM Replacement
  1. Samsung Series 5 Ultrabook RAM Replacement, Remove the Screws on the Back Cover: step 1, image 1 of 2 Samsung Series 5 Ultrabook RAM Replacement, Remove the Screws on the Back Cover: step 1, image 2 of 2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Samsung Series 5 Ultrabook RAM Replacement, Remove the Rubber Pads: step 2, image 1 of 2 Samsung Series 5 Ultrabook RAM Replacement, Remove the Rubber Pads: step 2, image 2 of 2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 Ultrabook RAM Replacement, Remove the Back Cover: step 3, image 1 of 2 Samsung Series 5 Ultrabook RAM Replacement, Remove the Back Cover: step 3, image 2 of 2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 Ultrabook RAM Replacement: step 4, image 1 of 2 Samsung Series 5 Ultrabook RAM Replacement: step 4, image 2 of 2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 Ultrabook RAM Replacement: step 5, image 1 of 1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 Ultrabook RAM Replacement, Remove the Battery: step 6, image 1 of 1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 Ultrabook RAM Replacement: step 7, image 1 of 1
    • Remove the battery from the laptop.
  8. Samsung Series 5 Ultrabook RAM Replacement, RAM: step 8, image 1 of 3 Samsung Series 5 Ultrabook RAM Replacement, RAM: step 8, image 2 of 3 Samsung Series 5 Ultrabook RAM Replacement, RAM: step 8, image 3 of 3
    • Use a spudger (or your fingers) to unhinge the left and right clips holding the RAM in place.
  9. Samsung Series 5 Ultrabook RAM Replacement: step 9, image 1 of 1
    • Carefully remove the RAM when both tabs have been fully disengaged.
3 other people completed this guide.
Javier Jimenez
223 Reputation
2 Guides authored
IUPUI, Team S1-G6, Harley Fall 2019 Member of IUPUI, Team S1-G6, Harley Fall 2019
IUPUI-HARLEY-F19S1G6
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 1,547
