Samsung Solstice Battery Replacement
  1. Samsung Solstice Battery Replacement, Removing the back cover: step 1, image 1 of 3 Samsung Solstice Battery Replacement, Removing the back cover: step 1, image 2 of 3 Samsung Solstice Battery Replacement, Removing the back cover: step 1, image 3 of 3
    • Gently slide the cover off of the phone by pushing it upwards, in the direction of the small arrow on the back cover.
    • Set the cover off to the side once you have removed it.
  2. Samsung Solstice Battery Replacement, Removing the battery: step 2, image 1 of 3 Samsung Solstice Battery Replacement, Removing the battery: step 2, image 2 of 3 Samsung Solstice Battery Replacement, Removing the battery: step 2, image 3 of 3
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool in between the rear end of the battery and the plastic frame.
    • Pry the battery up out of its recess and away from the phone.
Colton Glyder
301 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 33
All Time: 510
