Samsung Solstice Rear Facing Camera Replacement
  1. Samsung Solstice Rear Facing Camera Replacement, Removing the back cover: step 1, image 1 of 3 Samsung Solstice Rear Facing Camera Replacement, Removing the back cover: step 1, image 2 of 3 Samsung Solstice Rear Facing Camera Replacement, Removing the back cover: step 1, image 3 of 3
    • Gently slide the cover off of the phone by pushing it upwards, in the direction of the small arrow on the back cover.
    • Set the cover off to the side once you have removed it.
  2. Samsung Solstice Rear Facing Camera Replacement, Removing the battery: step 2, image 1 of 3 Samsung Solstice Rear Facing Camera Replacement, Removing the battery: step 2, image 2 of 3 Samsung Solstice Rear Facing Camera Replacement, Removing the battery: step 2, image 3 of 3
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool in between the rear end of the battery and the plastic frame.
    • Pry the battery up out of its recess and away from the phone.
  3. Samsung Solstice Rear Facing Camera Replacement, Remove the back cover: step 3, image 1 of 2 Samsung Solstice Rear Facing Camera Replacement, Remove the back cover: step 3, image 2 of 2
    • Remove the back cover by sliding the cover off of the phone by pushing it upwards, in the direction of the small arrow on the back cover.
  4. Samsung Solstice Rear Facing Camera Replacement, Removing existing SIM Card: step 4, image 1 of 3 Samsung Solstice Rear Facing Camera Replacement, Removing existing SIM Card: step 4, image 2 of 3 Samsung Solstice Rear Facing Camera Replacement, Removing existing SIM Card: step 4, image 3 of 3
    • Locate the SIM Card slot directly above the battery and below the phone camera
    • Place your thumb on the SIM Card in the slot, press down gently and slide the card away from the slot, until it comes out of the slot entirely
  5. Samsung Solstice Rear Facing Camera Replacement, Set SIM Card aside: step 5, image 1 of 1
    • Once you have removed the SIM card, set it aside from the phone.
  6. Samsung Solstice Rear Facing Camera Replacement, Removing the plastic mid-frame: step 6, image 1 of 3 Samsung Solstice Rear Facing Camera Replacement, Removing the plastic mid-frame: step 6, image 2 of 3 Samsung Solstice Rear Facing Camera Replacement, Removing the plastic mid-frame: step 6, image 3 of 3
    • Remove the six 0.4mm Phillips screws securing the midframe to the front panel assembly.
    • Grasp the the plastic midframe with your thumb and forefinger and lift it away from the phone.
  7. Samsung Solstice Rear Facing Camera Replacement, Motherboard Assembly: step 7, image 1 of 2 Samsung Solstice Rear Facing Camera Replacement, Motherboard Assembly: step 7, image 2 of 2
    • Use a plastic opening tool to pry the connectors from their sockets on the motherboard.
    • Gently remove the motherboard from the phone
    • Set the motherboard aside once it is free and separated from the phone
  8. Samsung Solstice Rear Facing Camera Replacement: step 8, image 1 of 2 Samsung Solstice Rear Facing Camera Replacement: step 8, image 2 of 2
    • Use a plastic opening tool to carefully pry the camera connector from its socket on the motherboard.
Colton Glyder
301 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 21
All Time: 333
