You're viewing a previously published version of this guide.  View latest version
Older Newer
Samsung T139 Camera Lens Replacement
Reagan May
Reagan May and 4 other contributors
Last updated on May 7, 2024
10 - 15 minutes
Moderate
Introduction
Go to step 1
If you are having problems with the camera on your Samsung T139, use this guide to replace it.
Tools
  1. Samsung T139 Camera Lens Replacement, Remove Back Cover: step 1, image 1 of 3 Samsung T139 Camera Lens Replacement, Remove Back Cover: step 1, image 2 of 3 Samsung T139 Camera Lens Replacement, Remove Back Cover: step 1, image 3 of 3
    • Power off your phone before beginning disassembly
    • Apply pressure to the back cover and slide towards the base
  2. Samsung T139 Camera Lens Replacement, Remove Battery: step 2, image 1 of 2 Samsung T139 Camera Lens Replacement, Remove Battery: step 2, image 2 of 2
    • With a plastic opening tool, lift and remove the battery
  3. Samsung T139 Camera Lens Replacement, Remove Screw Stickers: step 3, image 1 of 2 Samsung T139 Camera Lens Replacement, Remove Screw Stickers: step 3, image 2 of 2
    Tool used on this step:
    • Using the tweezers, remove the two rubber soles that cover the panel screws
  4. Samsung T139 Camera Lens Replacement, Remove Screws: step 4, image 1 of 2 Samsung T139 Camera Lens Replacement, Remove Screws: step 4, image 2 of 2
    • Remove two Phillips 1.0mm #0 screws
  5. Samsung T139 Camera Lens Replacement, Remove Face Plate: step 5, image 1 of 3 Samsung T139 Camera Lens Replacement, Remove Face Plate: step 5, image 2 of 3 Samsung T139 Camera Lens Replacement, Remove Face Plate: step 5, image 3 of 3
    • With the plastic opening tool, work around the face plate until it pops off
  6. Samsung T139 Camera Lens Replacement, Remove Camera Lens: step 6, image 1 of 2 Samsung T139 Camera Lens Replacement, Remove Camera Lens: step 6, image 2 of 2
    • Apply pressure to the lens, pushing it out the back
Reagan May
573 Reputation
5 Guides authored
Michigan Tech, Team 1-1, Lauer Fall 2014 Member of Michigan Tech, Team 1-1, Lauer Fall 2014
MTU-LAUER-F14S1G1
3 Members
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 232
