Samsung T139 Pad Buttons Replacement
  1. Samsung T139 Pad Buttons Replacement, Remove Back Cover: step 1, image 1 of 3 Samsung T139 Pad Buttons Replacement, Remove Back Cover: step 1, image 2 of 3 Samsung T139 Pad Buttons Replacement, Remove Back Cover: step 1, image 3 of 3
    • Power off your phone before beginning disassembly
    • Apply pressure to the back cover and slide towards the base
  2. Samsung T139 Pad Buttons Replacement, Remove Battery: step 2, image 1 of 2 Samsung T139 Pad Buttons Replacement, Remove Battery: step 2, image 2 of 2
    • With a plastic opening tool, lift and remove the battery
  3. Samsung T139 Pad Buttons Replacement, Remove Screws: step 3, image 1 of 2 Samsung T139 Pad Buttons Replacement, Remove Screws: step 3, image 2 of 2
    • Remove the four Phillips 1.0mm #0 screws
  4. Samsung T139 Pad Buttons Replacement, Remove Black Plastic Cover: step 4, image 1 of 3 Samsung T139 Pad Buttons Replacement, Remove Black Plastic Cover: step 4, image 2 of 3 Samsung T139 Pad Buttons Replacement, Remove Black Plastic Cover: step 4, image 3 of 3
    • Using the plastic opening tool, work around the edge of the black plastic cover until it pops off
  5. Samsung T139 Pad Buttons Replacement, Remove Side Buttons: step 5, image 1 of 2 Samsung T139 Pad Buttons Replacement, Remove Side Buttons: step 5, image 2 of 2
    • Remove side buttons by lifting them off the board
  6. Samsung T139 Pad Buttons Replacement, Remove Circuit Board: step 6, image 1 of 1
    • Lift circuit board up gently
    • Be careful to not pull ribbon cord apart when removing
  7. Samsung T139 Pad Buttons Replacement, Remove Button Pad: step 7, image 1 of 2 Samsung T139 Pad Buttons Replacement, Remove Button Pad: step 7, image 2 of 2
    • Lift away button pad
Reagan May
573 Reputation
5 Guides authored
Michigan Tech, Team 1-1, Lauer Fall 2014 Member of Michigan Tech, Team 1-1, Lauer Fall 2014
MTU-LAUER-F14S1G1
3 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 7
All Time: 457
