Samsung TFT Color YP-T7J The Battery Replacement
Dylan Peters
Dylan Peters and 4 other contributors
Last updated on August 1, 2019
5 minutes
Easy
Better Introduction
Tools
  1. Samsung TFT Color YP-T7J The Battery Replacement, The Back Cover: step 1, image 1 of 2 Samsung TFT Color YP-T7J The Battery Replacement, The Back Cover: step 1, image 2 of 2
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Samsung TFT Color YP-T7J The Battery Replacement: step 2, image 1 of 2 Samsung TFT Color YP-T7J The Battery Replacement: step 2, image 2 of 2
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Samsung TFT Color YP-T7J The Battery Replacement: step 3, image 1 of 3 Samsung TFT Color YP-T7J The Battery Replacement: step 3, image 2 of 3 Samsung TFT Color YP-T7J The Battery Replacement: step 3, image 3 of 3
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Samsung TFT Color YP-T7J The Battery Replacement, The Battery: step 4, image 1 of 2 Samsung TFT Color YP-T7J The Battery Replacement, The Battery: step 4, image 2 of 2
    • Once the back cover has been removed the battery will be visible.
    • Pry the battery from the device.
    • NOTE: The battery should still be connected to the device
  5. Samsung TFT Color YP-T7J The Battery Replacement: step 5, image 1 of 2 Samsung TFT Color YP-T7J The Battery Replacement: step 5, image 2 of 2
    • Unplug the battery connecting cables.
    • NOTE: The battery now should be free from all connections to the device.
Dylan Peters
409 Reputation
4 Guides authored
Clemson, Team 14-8, Benson Fall 2013 Member of Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
3 Members
7 Guides authored
One Comment
Nice instructions. Any idea where I can purchase a new battery that will fit?
grgermain - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 12
All Time: 1,962
