Samsung TL220 AF Assist Lamp Replacement
  1. Samsung TL220 AF Assist Lamp Replacement, Light Bulb: step 1, image 1 of 2 Samsung TL220 AF Assist Lamp Replacement, Light Bulb: step 1, image 2 of 2
    • Begin with unscrewing the seven outside shell 4 mm Philip screws with the Philips screw driver.
    • Now carefully pry open the back casing with the ifixit plastic opening tool.
  2. Samsung TL220 AF Assist Lamp Replacement: step 2, image 1 of 2 Samsung TL220 AF Assist Lamp Replacement: step 2, image 2 of 2
    • Now that you have the back casing off, gently remove the LCD screen up and to lay on top of the table to the right.
    • Next unscrew with the same screw driver, the 4 mm Philip screws on the back panel.
  3. Samsung TL220 AF Assist Lamp Replacement: step 3, image 1 of 2 Samsung TL220 AF Assist Lamp Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Unclip the four connecters that hold down the orange copper film strips with the plastic opening tool.
    • Then carefully pull out the three film strips with the ifixit tweezers.
  4. Samsung TL220 AF Assist Lamp Replacement: step 4, image 1 of 1
    • Remove the 4 mm Philip screws located above the center film strip with the Philip screw driver. This will allow the top frame to come loose to take off.
  5. Samsung TL220 AF Assist Lamp Replacement: step 5, image 1 of 1
    • Then pull the black claw located at the bottom right of the camera, to the right with the plastic opening tool. This holds the main plate down.
  6. Samsung TL220 AF Assist Lamp Replacement: step 6, image 1 of 1
    • Slowly lift with your fingers, the top frame of the camera up, disconnecting it from the main piece.
  7. Samsung TL220 AF Assist Lamp Replacement: step 7, image 1 of 1
    • This piece disconnected exposes the light bulb that you can change out at this point in the guide.
chelsa
358 Reputation
3 Guides authored
3 Tech Girls Member of 3 Tech Girls
Community
2 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 190
