Samsung TL220 LCD Screen Replacement
  1. Samsung TL220 LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Begin with unscrewing the seven outer screws on the camera. There is one on each corner and then three at the bottom.
  2. Samsung TL220 LCD Screen Replacement: step 2, image 1 of 1
    • Now carefully pry open the back casing with the ifixit plastic opening tool.
  3. Samsung TL220 LCD Screen Replacement: step 3, image 1 of 1
    • When the back casing is off, gently move the LCD screen to the side.
    • And then remove the three inner screws to remove the inside case.
  4. Samsung TL220 LCD Screen Replacement: step 4, image 1 of 1
    • Unclip the four connectors that hold down the orange copper film strips.
    • Then carefully pull out the three film strips with the ifixit plastic opening tool.
  5. Samsung TL220 LCD Screen Replacement: step 5, image 1 of 2 Samsung TL220 LCD Screen Replacement: step 5, image 2 of 2
    • Remove the screw located above the center film strip. This holds the top frame in place.
  6. Samsung TL220 LCD Screen Replacement: step 6, image 1 of 1
    • Unclip the four connectors to release the film strips.
  7. Samsung TL220 LCD Screen Replacement: step 7, image 1 of 1
    • Next unclamp the connector to release the film strip and then you can replace your LCD screen.
2 other people completed this guide.
Lesley
170 Reputation
1 Guide authored
3 Tech Girls Member of 3 Tech Girls
Community
2 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 20
All Time: 737
