Samsung U28E510 Motherboard Replacement
  1. Samsung U28E510 Motherboard Replacement, Motherboard: step 1, image 1 of 3 Samsung U28E510 Motherboard Replacement, Motherboard: step 1, image 2 of 3 Samsung U28E510 Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the cover and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • Lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Motherboard Replacement: step 2, image 1 of 2 Samsung U28E510 Motherboard Replacement: step 2, image 2 of 2
    • Flip the monitor over so that it is facedown.
    • Remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove backing to reveal signal/power board in center.
  3. Samsung U28E510 Motherboard Replacement: step 3, image 1 of 2 Samsung U28E510 Motherboard Replacement: step 3, image 2 of 2
    • Ensure to grip the connection plugs when removing wires to prevent damage to wires.
    • Unplug wires connected to supply (one on the left and one on right).
    • Disconnect the signal ribbon cable.
    • Pull the motherboard shield off—it's adhered in place by tape, so some force may be needed.
  4. Samsung U28E510 Motherboard Replacement: step 4, image 1 of 2 Samsung U28E510 Motherboard Replacement: step 4, image 2 of 2
    • Lay piece upside down.
    • Use a #2 Phillips screwdriver to remove the two screws that secure the motherboard.
    • Lift the motherboard out of the metal shield.
To reassemble your device, follow these instructions in reverse order. Ensure the bezel snaps in place all around monitor.
3 other people completed this guide.
Melina
154 Reputation
1 Guide authored
Cal Poly, Team S11-G1, Banghart Winter 2018 Member of Cal Poly, Team S11-G1, Banghart Winter 2018
CPSU-BANGHART-W18S11G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 23
All Time: 1,378
