Samsung UBD KM85C Outer Shell Replacement
  1. Samsung UBD KM85C Outer Shell Replacement, Outer Shell: step 1, image 1 of 1
    • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
  2. Samsung UBD KM85C Outer Shell Replacement: step 2, image 1 of 2 Samsung UBD KM85C Outer Shell Replacement: step 2, image 2 of 2
    • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
  3. Samsung UBD KM85C Outer Shell Replacement: step 3, image 1 of 3 Samsung UBD KM85C Outer Shell Replacement: step 3, image 2 of 3 Samsung UBD KM85C Outer Shell Replacement: step 3, image 3 of 3
    • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
  4. Samsung UBD KM85C Outer Shell Replacement: step 4, image 1 of 1
    • Remove the cover from the device.
3 other people completed this guide.
Breanna Ainsworth
258 Reputation
1 Guide authored
Baylor, Team S2-G1, Johnson Spring 2018 Member of Baylor, Team S2-G1, Johnson Spring 2018
BU-JOHNSON-S18S2G1
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 228
