Samsung UBD-K8500 Circuit Board Replacement
  1. Samsung UBD-K8500 Circuit Board Replacement, Top Panel: step 1, image 1 of 2 Samsung UBD-K8500 Circuit Board Replacement, Top Panel: step 1, image 2 of 2
    • Remove the six 10 mm screws from the back of the unit using a Phillips #0 screwdriver.
  2. Samsung UBD-K8500 Circuit Board Replacement: step 2, image 1 of 2 Samsung UBD-K8500 Circuit Board Replacement: step 2, image 2 of 2
    • Carefully lift up the top panel.
    • There is a cables that must be disconnected before completely removing the panel.
    • Detach the cable connecting the top panel to the motherboard.
    • Take the top off and set it to the side.
  3. Samsung UBD-K8500 Circuit Board Replacement, Circuit Board: step 3, image 1 of 1
    • Using your fingers, carefully pinch the clipping part of the four connectors and gently pull them out of their sockets.
  4. Samsung UBD-K8500 Circuit Board Replacement: step 4, image 1 of 2 Samsung UBD-K8500 Circuit Board Replacement: step 4, image 2 of 2
    • Gently pull out the two blue tabs of the ribbon connectors.
  5. Samsung UBD-K8500 Circuit Board Replacement: step 5, image 1 of 2 Samsung UBD-K8500 Circuit Board Replacement: step 5, image 2 of 2
    • Remove the three 7 mm screws from the circuit board using a Phillips #0 screwdriver.
  6. Samsung UBD-K8500 Circuit Board Replacement: step 6, image 1 of 2 Samsung UBD-K8500 Circuit Board Replacement: step 6, image 2 of 2
    • Gently pull out the circuit board.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 123
